Paypal Donation Available PM By Going Here For Details. Benefits In Return For Donations See Here
Results 1 to 6 of 6
Thread: Must read before using : Gamekiller, GameCIH, GameGuardian, Hexeditor. Game Cheat/Memory Editor/Crack/Hack Tool
    beautyangel's Avatar
    VIP Donator
    Mar 2010
    Robin Hood.Thanks to me,Multinational companies, pay less taxes. Sharing, I relieve their portfolio.
    Old Old ZTE Rooted.
    guide Must read before using : Gamekiller, GameCIH, GameGuardian, Hexeditor. Game Cheat/Memory Editor/Crack/Hack Tool
    Well Lets Start. Game Cheat/Memory Editor/Crack/Hack Tools/TITANIUM BACKUP
    First of All. U MUST BE ROOTED.
    Softwares : Gamekiller, Gamecih, GameGuardian, Hex-editor, DaxAttack v2.0 (Cheat Engine Gamevil undetected!), GameGuardian Plus v3.2 (Sparda), MHX V.3.3.4 (Sparda), Haxplorer TITANIUM BACKUP SAVE GAMES
    See Below Explanations for SERVER SIDED GAMES.
    Gamekiller
    Game Killer v2.60 Patched
    Requirements: Android 2.2, Rooted
    Videos Tutorial How To Hack with Gamekiller
    Features:
    1. Search game value with precise number.
    2. Search game value with vague instructions, e.g. larger or smaller.
    3. Lock the game value to a fixed number.
    4. Save/Load the managed list.
    5. Touch GameKiller sprite to bring up the tool during gaming.
    6. HEX edit
    7. Dump code
    8. More.
    GameKiller_2.60 patched. Coolypf.zip
    http://www74.zippyshare.com/v/74370915/file.html
    GameCIH Lite Version 3.0.0 !!!GAMECIH DO NOT WORK WITH ANDROID ICS (4.0) / ANDROID JELLYBEAN 4.1.2, 4.2 !!!
    Requirements: Android 1.5+, root
    Videos Tutorial How To Hack with GameCIH
    Tutorial:
    A game is pretty simple to use. but i will do a step by step guide:
    1. If you don't know what is root, or dont know how to root, you are on the wrong thread. Come back after exploring xda
    2. Download the version that you wish to use, i use older one, the reason i did that is because i didn't need the latest features of GameCIH.(about features read changelogs on gamecih site)
    3. Install it, and open, put it on your phone memory, and give it root access.
    4. When you open it, assign a key (i use VOLUME DOWN), don't exit it just use home so you can continue(for exit use menu exit).
    5. Open a game that you wish to cheat in. I personally tried it on Defenders game..
    6. Start playing the level, and pause it after taking a note how much gold/crystals/stars or anything you have.
    7. Press Volume down, Input number, and write amount of gold that you have. It will list a lot of numbers and stuff, 1 of them is our gold .
    8. Press back, resume game, continue playing, kill some monsters, earn some gold, then pause again and input the new amount of gold that you have. Now it should list a single number beneath.If not repeat this step.
    9. Press on that number, modify it to amout that you want, after pressing okay, you will have the gold you typed in...
    10. Now you can go spend what you hardly earned with cheating the game.
    GameCIH Lite Version 3.0.0 "GameCIH.apk"
    http://www48.zippyshare.com/v/80487935/file.html
    GameGuardian 6.0
    http://appaggie.com/appimg/i/d/v/a/q...aqua.bulldog-4
    Videos Tutorial How To Hack with GameGuardian
    Main Features:
    5. Touch Guardian sprite to bring up the tool during gaming.
    Enjoy playing games in your own way!
    Want to report bugs?
    Mali: [email protected]
    I really appreciate your help.
    Key words: game cheat, game cheating, memory edit, memory modify, crack, hack
    What’s in this version:
    Use sprite icon instead of hot-key to bring up the tool.
    Enhance searching range and performance.
    Support 1/2/4 bytes data.
    Keep memory footprint small, use disk storage instead.
    GameGuardian_6.0.0.zip
    http://http://www35.zippyshare.com/v/49079693/file.html
    Cheater v2.0-MODDED (ROOT) Courtesy of SPARDA Brother. Thx goes to him.
    Cheater it's a tool for easily edit the xml files encoded in utf-8 format.
    Supported languages:
    -English
    -Russian
    FOR ROOT USERS ONLY
    CURRENT VERSION:
    2.0-MODDED By SPARDA/FREE-WITHOUT ADS
    http://www1.zippyshare.com/v/7996741/file.html
    HexEditor v2.0.20 FOR ANDROID
    Requirements:Android 2.1 +
    Overview: Hex editor for yours binaries
    HexEditor v2.0.20.apk
    http://www36.zippyshare.com/v/8826821/file.html
    We can also Use A hex editor for PC to hack games.
    DaxAttack v2.0 Courtesy of DAX Brother. Thx goes to him. FOR ANDROID
    DaxAttack v2.0
    Requirements: 1.6+/Rooted Device
    NEW Memory Editor.
    YOUTUBE
    http://www.youtube.com/watch?v=BxPt-...layer_embedded
    App Name: DaxAttack
    Version: 2.0
    Use: Memory Editor/Hacking/Modding Games
    Root Needed: Yes
    Detection: Undetectable =^_^=
    ***Updates In Vrs. 2.0***
    * Undetected By Gamevil
    * Tweaked Some Settings. {Hopefully it fixes the long wait for some searches}
    http://www71.zippyshare.com/v/30953247/file.html
    GameGuardian Plus v3.2 Post and Courtesy of SPARDA Bro [Updated] Thanks bro
    [QUOTE]Features:
    Without it, you are played by games; with it, you play games in your own rules!
    “Game Guardian” is a game hack/alteration tool. With it, you can modify money, HP, SP, and much more. You can enjoy the fun part of a game without suffering from its unseasonable design.
    This app was released early of this year, was available on Play Store but seems that now it's unavailable. What's so special? It's totally free and has no limitations. Plus, it is less detectable by anti-cheat apps and has a lock function to lock in a value (good to make HP permanently 100%) (The only ad will appear when you want to use lock function, will be explained later). In a nutshell, it is lighter and more customisable than Game CIH.
    *ROOT ONLY*
    This tool only works in rooted devices!
    Main Features:
    6. Change game speed.
    What's in this version:
    -Undetectable.
    -New icons.
    http://mirrorstack.com/78802ioky9tk
    MHX V.3.3.4 Post and Courtesy of SPARDA Bro [Updated] Thanks bro
    Requirements: Android 1.52, Rooted
    Game Cheater Tool : UNDETECTABLE. Released BY SPARDA
    MHX V.3.3.4
    http://mirrorstack.com/tb9l8tf72l89
    Titanium Backup FOR ANDROID U MUST BE ROOTED.
    Titanium Backup Pro v6.0.3.1 Patched Thanks to coolypf Bro. U R THE BOSS DUDE.
    Requirements: 1.5+
    EXTREMELY powerful tool. Backup ALL APPS, GAMES and More......
    DEPTH REVIEW TB PRO
    NEW TB PRO DEMO
    http://www.youtube.com/watch?v=YU33zabluSY&hd=1
    http://www47.zippyshare.com/v/95015014/file.html
    SERVER SIDED GAMES :
    SERVER SIDED GAMES! You can't cheat something that doesn't exist on your local device.
    server sided games are where data is sent from there data base to your phone.so its not not saved on your phone its being streamed to your phone.now there are apps that can see what is being received from there data base and edit it.
    The only way of hacking serversided games with info about gold and stuff is packet editing it depends what game it is and it's too loooooonggg
    Post Will be [Updated Regularly].................................................. .................................................. .........
    Matrix by Neo's Avatar
    ~MPT Modder~
    VIP Donator
    Mar 2012
    Zion
    Samsung Galaxy S III
    Re: Must read before using : Gamekiller, gamecih, Gameguardian, hexeditor. Game Cheat/Memory Editor/Crack/Hack Tool
    Great tutorial bro
    SPARDA's Avatar
    Banned
    Dec 2012
    HELL
    HELL'S DEVICE
    R: Must read before using : Gamekiller, gamecih, Gameguardian, hexeditor. Game Cheat/Memory Editor/Crack/Hack Tool
    @beautyangel
    Yes, good tutorial, but you must add also haxplorer, mhx, and gameguardian plus
    Sweety97's Avatar
    Special Member
    Dec 2011
    Xperia
    Ohh my how i Missed this...will gonna try
    http://www.mydroidapp.org/
    Let me know if you have any Request. :okm:
    dickysinaga's Avatar
    Sep 2013
    Re: Must read before using : Gamekiller, gamecih, Gameguardian, hexeditor. Game Cheat/Memory Editor/Crack/Hack Tool/TBACKUP
    I've tried to edit coin data+score on LINE pop game using Game Killer, the numbers changed but not permanent effect. Numbers back to its real stat anytime i tried to purchase something (coins). Anyone could guide me with this?
    Cheva's Avatar
    Feb 2011
    indonesia
    Rom
    v 03.70
    where is Haxplorer?
    btw the link for GameGuardian Plus, and DaxAttack is down, please reup
