Paypal Donation Available PM By Going Here For Details. Benefits In Return For Donations See Here
Results 1 to 7 of 7
Thread: [ROM][4.4.4][I9300I] POPKAT™ Note 4 port
    PARABOTITELb's Avatar
    Jul 2012
    USA
    Nokia 3310
    rom [ROM][4.4.4][I9300I] POPKAT™ Note 4 port
    The firmware in the style of Note4
    PoPKat™ Features
    Note 4 my files
    Note 4 Gallery
    Note 4 S voice
    Note 4 Setting
    Note 4 Touchwiz
    Note 4 system ui
    Note 4 weather widget
    NOTE 4 boot animation
    Note 4 framework
    Updated aroma
    Note 4 messages
    Note 4 dialer
    Stok camera
    Note 4 lockscreen
    Note 4 power saving mode
    Note 4 s finder
    Note 4 quick connect
    Note 4 keyboard
    Note 4 wallpapers
    Note 4 Studio
    Note 4 side sync
    Note 4 All together
    Note 4 memo
    Note 4 clock
    and many more Cool features
    Screenshot
    Bugs
    PIN code for the lock screen (don't try-will cause the screen lock, then only the firmware will help.
    * Desktop S-view
    how to install Rom:
    1) download the firmware archive.
    2) copy the file onto the SD card.
    3) Reboot your smartphone into recovery mode.
    4) before installing do wipe 3: date, cache and cache delvik.
    5) choose the location where you copied the archive with the firmware. Click on the file. Install the firmware by using Aroma Installer
    6) after installing firmware not reboot
    7)Installation of a patch for work of Wi-fi
    I express special gratitude:
    Contributors:
    @adityaupreti
    For the firmware - http://forum.xda-developers.com/gala...g7102-t3222589
    @ravikanthchary :
    For the settings file
    DOWNLOAD
    WI-FI Patch
    Patch for screen rotation.
    Download
    Installation :
    Extract the contents of the file using the file manager on the patch /system/lib/hw and system/vendor/lib/hw with replacement and setting the permissions of 0644
    NEW LOLLIPOP MATERIAL FRAMEWORK by adityaupreti
    framework glitch fixed
    and new white lolipop styled framework
    lollipop platlogo
    NOTE:i have not tested so dont know works or not
    How to install
    put framework-res.apk to framework folder and set permissions
    Download
    https://mega.nz/#!5h1hWZpD!YVCDMULxM...LngMCG_X3EUKVE
    test and report
    Signature Removed - Please Read Forum Rules.
    skynetfroggy's Avatar
    Donator
    Mar 2012
    Localhost
    Galaxy S7 Edge
    Rom
    MM 6.01
    Gender
    male
    Re: [ROM][4.4.4][I9300I]POPKAT™ Note 4 port
    Thanks for the rom
    MPT deserve a donation ...
    dls7882's Avatar
    Jun 2016
    Quote Originally Posted by skynetfroggy View Post
    Thanks for the rom
    Salut, c'est bien toi.? Je découvre ce forum, il est extra
    Mouse's Avatar
    Donator
    Aug 2012
    Mouse Hole
    AnDRoid
    Gender
    Rodent
    Quote Originally Posted by dls7882 View Post
    You must speak in English at forum
    dls7882's Avatar
    Jun 2016
    Quote Originally Posted by Mouse View Post
    Hello.? yes I understand, the greetings are not needed here.?
    Blu Sky's Avatar
    Administrator
    MPT Donator
    Extraordinary Poster
    Nov 2012
    ♥ ☛ Australia™ ® ♥ ~
    ☛ Samsung Galaxy Note 4 SM-N910G Phablet »
    Rom
    Android 6.0.1 Marshmallow / GPU: Adreno (TM) 420 / OpenGL ES-CM 1.1 [arm based]
    Gender
    Female
    Please use English on open forum as per forum rule, dls7882
    [Members Please Don't Just Download...
    Remember to help other members by posting one comment if working Or Not (Details About That Problem).
    We are a community, we meet here to share our release/uploads and share our mobile related knowledge]
    Examples of Share Files Upload Websites
    To avoid Making Reposts, try Advanced Search on Top RIGHT of the forum.
    How To Use Advanced Search efficiently
    Advanced Search --->>> Search Single Content Type --->>> Search for Posts --->>> Keyword(s): HERE --->>> Search Title Only --->>> Search in Forum(s): (Select which forum for your search) --->>> Search Now
    dls7882's Avatar
    Jun 2016
    Re: [ROM][4.4.4][I9300I] POPKAT™ Note 4 port
    Hello, ok thank you.
