Megabass (Audio booster) v1.0 + Noozy Player v3.0.2.3
Requirements: Android 2.2+
This mod can boost system sound to make more powerfull.
Fitur :
- MegaBass system with beats, srs and alsa
- Dsp mod and Dolby with more options:
- 1 option in compression
- 1 option bass ( I think you won't use bass option in MegaBass )
- 4 options in equalizer
- 2 options in loudness
- and 2 options virtual
- More clearly sounds
Changelog for V4 [Update 19th March 2013]
- we going to logic and clean audio so I remove Beats libraries from this mod and the results you can feel the different sound with before, so you must fresh install for this
note :
If you has installed MegaBass before...you must restoring your backup rom than install this mod
Installation :
- Backup your rom
- Remove DSPManager / others equalizer app (If you have here)
- Put the file in sdcard
- Go to CWM recovery
- Instal the file
- Reboot
WARNING:
Use at your own Risk! we will not be held responsible for any damage to your phone.
Download Instructions: geva28.
Megabass (Audio booster) v1.0:
http://uploaded.net/file/vgcmkjom
https://dailyuploads.net/61djgaanipl0
Noozy Player v3.0.2.3:
http://uploaded.net/file/5rau6rpz
https://dailyuploads.net/xhkfsobzxao0
